Gasket needed between block and PAS bracket?
My answer would be no BUT if you look behind that braket (two big posts) there is the old Pinto fuel pump take off, some blocks are blanked and others need a plate over that oval shaped bit with 2 bolt holes....my last 200 block had a plate over there and that DID have a gasket...I am sure a smear of make your own gasket sealer would be fine.
corrected my post to fuel pump......not oil
Jasesapphy
21-06-2008 06:42 AM
Stavros
11
26-05-2005 05:01 PM
