Unknown Cosworth Wiring Plug
Distributor, Crank Position Sensor and Idle Control Valve are connected to this part of the loom, this remaining plug is spare. I've borrowed a picture to show all the plugs.
http://i182.photobucket.com/albums/x...=1508180219133
It appears to be a cable much larger than standard 1.5mm coloured wires with a copper outer.
Can you help identify the plug please?
Could be the sensor (air temp) in the plenum.
It goes in the threaded hole in the middle of the plenum in this picture
