2WD Saff 6 degree beam geometry settings needed...
What settings do you guys use these days on a Saff 2WD? Is it these???:
FAST ROAD GEOMETRY SETTINGS
Front: 1.5 degrees negative camber, 2 mm toe-in
Caster as close to 3’30° as you can get
Rear: 1.5 degrees negative camber (not adjustable on standard rear beam, but will normally be around this
depending on ride height), up to 3 mm toe-in (using shims or by slotting the mounting points and tack-welding a washer to the beam in position after welding — as per the Group N cars).
Cheers lads.
Philip.
Cheers lads.
Philip.
