is there a relay for the front lights in a sierra ?
Old 16-11-2015, 12:51 AM
eddyj
eddyj's Avatar
Default is there a relay for the front lights in a sierra ?
have a ford sierra and my dips and fulls aren't working or the horn and there is no light coming on in the dash when I try put fulls on ?
could it be a relay and where abouts would it be ?
Old 16-11-2015, 06:11 AM
Received 1,044 Likes on 998 Posts
The relay is in the fuse box. Try cleaning the earth points behind the front headlights. There should be a 10mm bolt each side holding the earth wires to the front panel.
eddyj (16-11-2015)
Old 16-11-2015, 04:21 PM
dojj
Resident Wrestling Legend
dojj's Avatar
if the lights don't work it's normally the switch that's at fault
eddyj (16-11-2015)
Old 16-11-2015, 05:56 PM
eddyj
eddyj's Avatar
okay il try that .... theres notting coming on in the dash tho when I put lights to on position and put them to the fulls no blue light comes on dash
Old 16-11-2015, 05:58 PM
eddyj
eddyj's Avatar
what switch ? the one on the right of the stearing wheel for turning on the lights or the one that switches the dips and fulls on and off ?
Old 16-11-2015, 06:24 PM
dojj
dojj's Avatar
do you have a dimmer switch?
try moving that first as that's the easiest fix
after that it's the stalks, mainly the one that has the hazard light switch on it (on the left yes? ) as the one on the right has the light switch and the wipers (yes? )
it's been a decade or more since i've had my sierra so if things are a little wrong forgive me
have you checked the power coming out?
and what year is it?
Old 16-11-2015, 06:26 PM
dojj
dojj's Avatar
just seen that the horn don't work either, there is a 2 prong switch in the centre of the steering wheel which can sometimes fail when the contacts wear out, pop the centre horn push out and see if toucihng the wires together does the trick
otherwise removing the cowling you should be able to see the plug for the horn (i think it's a white 2 pin big plastic plug) and shorting them out should do the trick
eddyj (16-11-2015)
Old 16-11-2015, 08:33 PM
eddyj
eddyj's Avatar
its a 92 what do you mean by a (dimmer switch ) and yes your correct on the sides that's how mine is ....
okay thanks il check that for the horn
Old 17-11-2015, 12:42 PM
dojj
dojj's Avatar
Behind the stalks underneath the instrument panel there might be two rolling switches, one that dims the dash lights and one that changes the died of the wipers on their intermittent setting
It might be as simple as a stuck on one
eddyj (17-11-2015)
PAUL V
18-11-2015 09:20 PM
josenovo
17-11-2015 01:08 PM
AlexisFuentes
Ford Fiesta
13-11-2015 09:25 AM
eddyj
12-11-2015 03:42 PM
shark91
12-11-2015 04:38 AM
Quick Reply: is there a relay for the front lights in a sierra ?
