Compression strut kit
Old 25-06-2015, 05:20 PM
Toe Knee
Toe Knee's Avatar
Default Compression strut kit
Are they worth having on a 2wd saph?!
Going through a full resto and was wondering weather it's worth doing away with the arb and having these instead?!
Changing most things for new so thought I'd ask!!
Old 25-06-2015, 05:31 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I'm looking into this as well for mine. From what I've read it's only worth doing if you fit a bladed roll bar as well
Old 25-06-2015, 08:02 PM
IainRS1700T
IainRS1700T's Avatar
For a road car?
No. They're hard mounted at chassis and TCA and transmit a lot of NVH.
You'll also need to find an ARB solution especially if running road biased suspension, and then it can start to get (unnecessarily) expensive!
Good top mounts and adj TCA's will provide good adjustability for your geo set up, but not at the expense of ride comfort. The H14 arb with poly bushes is also a good option.
Iain
Old 25-06-2015, 08:38 PM
Toe Knee
Toe Knee's Avatar
Perfect answer!!!
What's the h14 arb not heard of it?!!
Ignore just done a Google search its the 2wd one which I already have lol
Old 27-06-2015, 07:34 AM
IainRS1700T
Cool. Yes RS500 & Sapph iirc.
Gives a bit more castor (aids high speed stability)
Old 05-07-2015, 05:03 PM
matthewpickup
matthewpickup's Avatar
ive got gaz coilovers and compression struts (no anti roll bar) handles really well , bit harsh compared to arb with poly bushes so don't think I would recommend for everyday use , also mines is 4x4 if it makes a difference
arkeye
Ford Focus ST
20-02-2016 01:22 PM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
Quick Reply: Compression strut kit
