2wd cams into 4wd head
Old 16-06-2014, 11:50 AM
ram
Has a large member
ram's Avatar
Default 2wd cams into 4wd head
Im swapping all the bits off my old 2wd head onto a fresh 4x4 one.
Other than 4x4 cam bearings and seals is there anything else i need to do in order to make them fit?
i know 4x4 setups run with a spacer but is that still relivant when using 2wd cams?
Thanks
Old 17-06-2014, 10:20 PM
matthewpickup
matthewpickup's Avatar
dont think so as the bearing has the extra part on it so no need for the spacer , front caps are different too as holds the bearing differently
Old 18-06-2014, 06:07 PM
ram
Has a large member
ram's Avatar
Yeh I've discovered it can't be done. Know of ppl who run them but the belt doesn't sit bang in the middle of the pulley, not a risk I'm willing to take!
Got an old pair of 4x4 cams stored away that will just need the lobes scotching so will use them!
dombanks
21-09-2015 08:38 PM
3doorcozmess
15-09-2015 06:06 PM
rsstav
07-09-2015 04:43 AM
rog
04-09-2015 07:24 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: 2wd cams into 4wd head
