Stiffer or longer?
Old 17-02-2014, 03:19 PM
Tomyspeedy
Tomyspeedy's Avatar
Default Stiffer or longer?
Hello everyone
As the title suggests I have a query about my springs.
I'm currently running a set of Gaz Golds:
front 8 inch long x 400 lbs 2.5" ID
rear 12 inch long x 225 lbs
The front has been fully adjusted and the ride height is too low.
My question is, should I go for longer springs of the same strength or for stiffer ones?
Also I would very much appreciate any recommendations for vendors of said springs.
Old 17-02-2014, 09:42 PM
BIL N KEL
BIL N KEL's Avatar
Email gaz direct. I contacted them about rebuilding mine as one of the rears are leaking.
Billy
Old 19-02-2014, 07:09 PM
matthewpickup
matthewpickup's Avatar
mines are gaz coil overs with 10" springs and are 325lbs spring , but this was fine with the pinto engine , but with the yb in it I am not sure how it will be yet
as this set up was done by gaz for the pick up and engine set up so I was told
DavidK
27-09-2015 02:55 PM
TC-ST3
26-09-2015 04:47 PM
Ridgey
13-09-2015 08:43 PM
mike elsome
Ford Range
09-09-2015 05:05 PM
Quick Reply: Stiffer or longer?
