Brake bleeding problem....
Old 16-02-2014, 10:02 AM
peteh
peteh's Avatar
Default Brake bleeding problem....
Ok situ is, my cars been arse end up for a few months while I fitted my new rear end and supra diff, now I'm up,to the stage where I wana bleed the rear brakes...
I connected all the hoses back up and calipers, went to bleed them yesterday and the peddle won't go down to push the new fluid through with the nipples open etc etc. checked all the line while fitting by blowing through them but nothing's happening.
The car hasn't got the batt fitted, would this help by putting power to the abs, or have I a seized master cylinder or something?
Any help would be great.
Old 16-02-2014, 10:18 AM
JamesH
JamesH's Avatar
From memory you need ign on to bleed the rears
Old 16-02-2014, 11:43 AM
cossie moon
Durham RSOC member
cossie moon's Avatar
As above you need power because you need ignition key on position 1 to power pump.
Old 16-02-2014, 11:50 AM
peteh
peteh's Avatar
Phew!! Thanks a lot lads.
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Brake bleeding problem....
