Alloy Vernier Camshaft Pulleys
Old 23-01-2014, 05:32 AM
OZHCR32
OZHCR32's Avatar
Default Alloy Vernier Camshaft Pulleys
Have done a search but not able to find anything.
Anyway, my current Piper vernier camshaft pulleys are shagged with:
Inlet cam - 18thou run out
Exhaust pulley - 5thou run out
Visibly the inlet cam had a hell of a wobble...cams have come back ok. So looking at buying some Kent pulleys from Burton Power.
Question is, have people noted any increased wear from the alloy pulleys vs steel? Is that sort of wear/damage commong on high kms Piper Pulleys?
Its quite possible that they were 2nd hand jobbies used in the rebuild or just simp;ly damaged...just wondering if this is one of those things and that Piper are recognised as being better than Kent and should buy another set of Piper???Another brand???
Thoughts???
Old 24-01-2014, 09:53 AM
Karl 3dr
Karl 3dr's Avatar
I've had adjustable Kent ones on one of my old engines with no problems, admittedly I didn't do many miles with them though. If I was to use some again though I think I'd go for the pegged Quaife ones though, firstly because there's supposed to be less chance of them slipping, and secondly because they look good lol
Old 24-01-2014, 11:19 AM
James @ M Developments.
James @ M Developments.'s Avatar
It is a common problem on the alloy pullies, i have piper ones on mine and there is certainly some wear on them,
We offer these,
http://www.shop.motorsport-developme...leys-863-p.asp
Which are hard anodised, which from what i have seen stops this from happening. I think i will be fitting some to mine.
The quaife ones are also very good, and they offer a steel version.
Old 25-01-2014, 07:43 AM
BRAMMER
BRAMMER's Avatar
I've got quaife steel pulleys and they only cost about £130 delivered
Old 25-01-2014, 07:52 AM
Turbosystems
Super Moderator
Turbosystems's Avatar
All the well known brands of alloy pulley are hard anodised they do not last anywhere near as long as steel ones
Old 25-01-2014, 08:20 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
You can buy hardened pulleys which will not wear as quick as normal alloy type ones that kent, piper, burton etc offer.
Old 26-01-2014, 01:21 AM
OZHCR32
OZHCR32's Avatar
I grabbed some Kent ones for the time being. Will keep a eye on them and if need by may go the Quaife route
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
Quick Reply: Alloy Vernier Camshaft Pulleys
