Modeen oil cooler
Modeen oil cooler
My oil cooler looks a bit rust inside (cosworth 2WD) I think its called a Modeen cooler.
Can you remove them or is it best to keep em.
Can new ones be purchased
Thanks
Thanks
You can do it like that .
Or you simply just remove it and replace the filter,
But off the top of my head I can't remember whether the fitting that holds it on is a two peice item or one peice .
If it's two peice you should be good to go .
If it's one peice then you will need a shorter one
Mine is a single bolt type thing that holds it on in the centre.
