Saph fuel tank removal
Stripping everything off the rear end on my saph if removed the bolts that are holding the tank up and removed fuel pump pipe to the tank but how do you remove the fuel filler neck from tank?? Not removed one before so any help would be great.
fuel filler neck is just a push fit mate, plenty of wd then the tank should pull away from it when lowering the tank.
cheers nick
cossie fan (unluckerly)
Is there a screw by the filler neck I'm sure there was in mine and I think some thing under the wheel arch trim? I dropped my tank out with the neck still attached
steerfromdarear
28
29-01-2016 06:14 PM
ekjim
17-08-2015 08:57 PM
