Saph Boa turbo conversion!!
#486
![Name: image_zps62336bff.jpg
Size: 111.7 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/50117d1501356903-saph-boa-turbo-conversion-image_zps62336bff.jpg)
Today fitted cradle and removed cut out switch in boot along with excess wiring to it and wired pump direct, got to run pipe from accumulator too new filter and connect the filter up both sides then job done!
#490
Got my raven dash today off of Will(Puss2) real nice bloke and lovely saph, and as Simon (electrician) is coming Sat/Sun morning for my injector/injector loom issue I removed old dash so that he can tidy up my ecu loom behind dash.
![Name: image_zpsd77bc8fd.jpg
Size: 117.5 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49885d1501356263-saph-boa-turbo-conversion-image_zpsd77bc8fd.jpg)
![Name: image_zps1cd6158c.jpg
Size: 128.4 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49886d1501356263-saph-boa-turbo-conversion-image_zps1cd6158c.jpg)
#494
Not heard from Simon so I take it he coming tomorrow if at all any how, I removed the plenum today to access injectors/loom looks so so but looks can be deceiving!
![Name: image_zpsf87c4a8c.jpg
Size: 143.8 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49828d1501356079-saph-boa-turbo-conversion-image_zpsf87c4a8c.jpg)
![Name: image_zps7feab412.jpg
Size: 138.3 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49829d1501356079-saph-boa-turbo-conversion-image_zps7feab412.jpg)
Most likely tidy dash loom and fit raven dash tomorrow....
#495
Simon never came so nothing got done but today I finished work early so when I got home I took my Boa thermostat housing and 2wd cossie thermostat housing down to my cousins workshop to cut modify to be re welded, also spoke to my uncle who told me step by step how to check my injectors and injector loom so once I'm home I will have a go.
![Name: t1_zpse6ebec11.jpg
Size: 100.6 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49456d1501354815-saph-boa-turbo-conversion-t1_zpse6ebec11.jpg)
![Name: t2_zps8d8ceea4.jpg
Size: 92.9 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49457d1501354815-saph-boa-turbo-conversion-t2_zps8d8ceea4.jpg)
![Name: t3_zps1e8756a8.jpg
Size: 107.9 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49458d1501354815-saph-boa-turbo-conversion-t3_zps1e8756a8.jpg)
![Name: t4_zpsf19b33a5.jpg
Size: 98.7 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49459d1501354815-saph-boa-turbo-conversion-t4_zpsf19b33a5.jpg)
(after)![Name: image_zpsade909de.jpg
Size: 102.4 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49460d1501354815-saph-boa-turbo-conversion-image_zpsade909de.jpg)
![Name: image_zps396cd01d.jpg
Size: 96.4 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49461d1501354815-saph-boa-turbo-conversion-image_zps396cd01d.jpg)
![Name: image_zpsf34ca9e8.jpg
Size: 121.7 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49462d1501354815-saph-boa-turbo-conversion-image_zpsf34ca9e8.jpg)
![Name: image_zps789ebfc9.jpg
Size: 107.1 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49463d1501354815-saph-boa-turbo-conversion-image_zps789ebfc9.jpg)
![Name: image_zpsfd998a65.jpg
Size: 63.6 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49464d1501354815-saph-boa-turbo-conversion-image_zpsfd998a65.jpg)
Then took to my mate Dave the welder but he had gone home early so looks like Monday now.
Once I got home I then turned my attention to the injectors, I followed my uncles instructions and low and behold found them all too be blocked. I continued following the instructions if I found them to be blocked and it worked they are now all free bar 1 injector, it was too late to test/check loom so will do that tomorrow!
(after)
#497
Today I removed the completely blocked injector left it too soak in injector clear for 10min then started to give it a 24v alternating pulse all ok now refitted tested injector loom all ok so fitted new inlet manifold (plenum) gasket and put engine all back together! Now just waiting on Monday to get thermostat housing welded then i can try engine and need to run her up to temperature with engine flush! My mate Aaron(bangerboyno1) also tightened up a few bolts and started to remove all the egr shit as i have decided to get rid of it now, also made a start on the wiring behind the dash fitting new plugs. Will post some more pics tomorrow...
#504
Any way today as soon as I was up and had dealt with my 1yr olds breaky etc I cracked on with car had to carefully drill out an old radiator bolt that snapped on removal I then fitted my Pace rad and partially piped up with old hoses as I have SfS silicone ones coming and got to dig out and fit my water swirl pot and weld thermostat housing.
![Name: image_zps46c8477b.jpg
Size: 127.1 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49246d1501354492-saph-boa-turbo-conversion-image_zps46c8477b.jpg)
![Name: image_zps11024e5d.jpg
Size: 126.6 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49248d1501354492-saph-boa-turbo-conversion-image_zps11024e5d.jpg)
![Name: image_zps7481453b.jpg
Size: 115.8 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49250d1501354492-saph-boa-turbo-conversion-image_zps7481453b.jpg)
![Name: image_zps5de38f3b.jpg
Size: 146.4 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49253d1501354492-saph-boa-turbo-conversion-image_zps5de38f3b.jpg)
![Name: image_zps04a3e672.jpg
Size: 152.8 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49256d1501354492-saph-boa-turbo-conversion-image_zps04a3e672.jpg)
I then turned my attention to the messy ECU loom behind dash with dash removed it was pretty easy I cut out old plugs as some of them had dodgy connections and used new water resistant plugs, just had my roast so may refit the dash in a bit if not I will do it tomorrow after work.
![Name: image_zps6d8ad59a.jpg
Size: 100.5 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49258d1501354492-saph-boa-turbo-conversion-image_zps6d8ad59a.jpg)
![Name: image_zpsc283ba9c.jpg
Size: 126.4 KB](https://passionford.com/forum/attachments/ford-sierra-sapphire-rs500-cosworth/49260d1501354492-saph-boa-turbo-conversion-image_zpsc283ba9c.jpg)
Ignore the brown earth that's been joined a few times that is only temporary changing that when I put dash back
#507
I did a few weeks back for about a minute (I had changed plugs and sprayed petrol/redex down bores as engine had sat then sprayed easy start in filter and bang she fired and ran for about a minute), but no not since I have sorted injectors and loom etc Ade said it will be ok to do so for 30 seconds (as there is no water in car hoses not all connected) I am going to wait untill tomorrow or Tuesday all I need is thermostat housing welded then its all good!!
#515
Fit my new twin 12" kenlowe fans-DONE
Fit my water swirl pot
Collect and fit my adapted thermostat housing
Refit prop
Refit clocks
Fit fan switch
Run engine up to temperature with engine flush
All should hopefully be done by this weekend or at least the majority of it.
#516
Today after work fitted my 12" kenlowe fans and I started her for 1st real time for a few mins all is fine had old ill on my doorstep not long after as she so loud on downpipes sounds like drag car my dickhead benefit street neighbour called them...... long story short I told them to fuck off!!
#519
Dnt you have too have sex 1st too have kids Glenn 😉😉lol! Was going to do the same but things dramatically changed and now we're actually glad we didnt as we have moved 3-4times since (through choice) also I always said i disnt want to be a parent with a child at school when he's 5-9 and me be 50+
#520
Went down welder after work today and my bits are not done he had some emergency work come in that took priority but promised me it will be done 1st thing in morning for me to collect in the afternoon (he is doing it as a favour so I cant really moan). As promised had her running again today and will upload vid when my youtube channel finishes uploading it!
