Saph Boa turbo conversion!!
#402
Hello peeps been a while had to have a break many things have happened, had a baby boy Brennan (shovel hands) who's now 5months 2 weeks old and I snapped both my achilles tendons and tore ligaments so couldn't work on car so fucked it off (not got rid of her) and fucked this off too (PF) as it was getting me down coming on here and not being able to do anything!
Anyhow onwards and upwards I'm back fighting fit back training again and finally after 6months have a mt75 rwd prop (think the 1 fitted is off Granada as its slightly to long), may also have sorted starter wont know until I fit prop and visit dojj.......
Right as for you mk22door I did txt u dnt know if u got it I will sort you that bit out I have not forgotten or I can sort you some £...
As its been so long I lost my list of things to do, off top of my head I got to fit new prop, fit the new speedo cable I got this week wire in a relay for fuel pump and 2 relays for twin fans change spark plugs and leads and get her started hopefully
#405
because i'd get into trouble selling it to you without posting it in the correct room for items for sale, i'm just letting you know i have found one whilst the old man was sorting the garage and it's got lots of dirty grease all over his hands
when you come to collect the other stuff we can sort out a price that you want to pay for it
#406
#409
nope got home early was grand weather but lil sis had baby 2 days ago and I not seen him yet so went to see my new nephew! Dnt worry it will be done i'll prob need your help too Fil as last one was a bastard on my own (gear box end)
#413
Congratulations to you and your Mrs with little Brennan
The achilles tendons sounds painful
As for the Saff, sometimes it's best just to leave it and have a break so you don't get too fed up and sell it on, glad to see your back on with it though - you will get there!
I get fed up of reading/looking at nice Sierra's on here too while I smoke round in the 1.8 hatch lool!
#414
Things have slowly moved a little forward as today I visited dojj and acquired a few parts that may or may not sort 1 or 2 of my issues we will soon see! and a few other bits and pieces I needed.... cheers dojj
#415
Did a quick once over of full snag list to be done asap;
remove prop and fit good one/hopefully this will sort starter issue
refit rear seat bolsters
ordered braided fuel pump loom/fit when arrives
wire up or order braided twin fan loom
fit elec sunroof motor
fit new speedo cable
re fit cossie clocks with rev counter
change front headlights or remove and re seal
get new car battery
new spark plugs and lead
get black dash and a few other pillar trims in black
pretty sure that's it.........
get new car battery
#416
Well today its wet, damp and bloody cold but went out to try and get propshaft off. Removed exhaust and centre bolts on prop removed 3 of the rear prop bolts could remove the other prop keeps spinning! All i can do for today its just to wet snd damp ground is soggy too!
#417
Right update time; due too the utter shit weather we have had I haven't been able to do anything to car but..... that hasn't stopped me getting bits, I have now got new leads and plugs (got to fit), brand new transit battery for car arrived today I also have a stainless straight through exhaust to replace the make do one I have. I have got to go collect the braided fuel pump loom this week also fitted rear seat bolsters. Been busy doing Mrs car as wheel bearing failed and clutch/gearbox
#418
It's been shite hasn't it!
I finally removed the full loom from the 4x4 (in the pissing rain) not the best day to do it but I was sick of seeing the shell sat there.
Keep at it mate, one day soon it'll all make sense
#420
car is currently on my drive stuck, to roll it in my garage I need to remove prop but when I jacked it up and put stands under it they were sinking lol I got most of prop off but 2 bolts are stiff as fuck and car was quite low at that point so gave up...
#423
Only just noticed ur comments should have txt/called me bud not much got a little fiesta zetec s to run about in till car sorted still waiting on mate for me to pick up that fuel pump loom he never about! Weather supposed to be good this week so will get prop off this week and try to fit the other! Fitted new battery starter still clicks so its not battery related!
#428
As of today my saph 24v should be finished before end of July I have provisionally sorted starter issue by having a recon company make me 1 gd starter out of 2 (take cog from 3 bolt starter and put in a 2 bolt starter) costing £90!
And next weekend I have someone local who builds sierra 24v's coming round to fit my fuel pump loom I now have and wire my twin fans and check al my wiring over then we will get it started!!!! Happy days then tax her and get her in use for few months till respray.........
#436
Update time; getting close now she lives had her started today thanks to Simon Halls, he came to mine today as last weekend me the Mrs and 3boys all came down with gastro virus, he checked all wiring over that I had connected up all ok ! Then we set about stripping my gd 2 bolt 2.8 starter motor and a seized 3bolt 2.9 starter donated by dojj taking the 10 sided spline from the 2.9 and putting it in to the 2.8 starter as the company who were going to do it originally started messing me about, we got the engine firing over but no start up, after 3 cans of fuel and some persuation she fired into life all but briefly...... bet my neighbours loved it as she is currently only on down pipes now issue that has arose my fuel pump seems dead/fucked it used to be noisey now you can barely hear it! also spark plugs need replacing hence her not staying running so have ordered some
My main issue is my prop I have removed it and it is 110% a 2ltr sierra twin cam prop so why is it so tight a few people have said i need an escos donut as theyre slightly thinner than the one I'm using!
#438
I mean I bolt end to diff and other too gearbox I basically have to force centre up with gd pressure to bolt it up, so its tighter than it should be, so tigh if I try to move car rear wheels do not turn but with prop removed all moves ok!
