camber on a sierra cosworth question
#41
Fixing Fords
ah see what you mean mate , but if like me you are running coilovers the car dose not move a great deal so the way the wish bone moves will be very little imo i think the diffrance would be seen mostly on a track car but i guess the diffrent beam is really a track set up as it can be changed for each track or weather , cant wait to get my camber shims
#43
evening people,fitted my rear shims today,no problem.
tried to move car forward and it was jammed/locked.
it seems from where the shims have pulled the drive shafts a little outwards that the bolts holding the cv joints to stub are fouling on the inside of the trailing arm.
anybody else had this problem?!!
if you look at rs mat photo above you will see bolt 1mm from arm
mark
mark
#44
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
