anti lag system
Old 19-03-2012, 09:07 AM
Themistoklis
Themistoklis's Avatar
Default anti lag system
hello. i have programm from STU. l8 ecu with coil pack
I have problem with anti lag and also Idle air control valve.
Idle air control valve:
works when I put the engine at 1500 rpm and stays stuck there. I tried three others and I have the same problem.
anti lag :
does not work when I open the switch. all you do is throw 500 rpm the engine idling
Can someone help me to find a solution to my problem.
Thank's a lot
Old 19-03-2012, 09:21 AM
cossie891
cossie891's Avatar
best bet is ring Stu
Old 19-03-2012, 09:25 AM
Turbosystems
Super Moderator
Turbosystems's Avatar
check your tps is set correctly
Old 19-03-2012, 09:28 AM
Themistoklis
what do you mean;
Old 19-03-2012, 09:29 AM
Themistoklis
What is TPS?
thank' a lot.
Old 19-03-2012, 09:51 AM
daviddunlop83
daviddunlop83's Avatar
Originally Posted by Themistoklis
What is TPS?
thank' a lot.
Throttle position sensor
Old 19-03-2012, 10:03 AM
Turbosystems
Super Moderator
lots of tech info here on settings for the weber
http://www.bigturbo.co.uk/
Old 19-03-2012, 10:06 AM
Themistoklis
Thank you. TPS is the case affect the anti lag and Idle air control;
Old 19-03-2012, 10:25 AM
Heitmann
Heitmann's Avatar
start by setting your base idle without the ISCV connected (on a warm engine)
Have you modified the ISCV, per MSD instructions, for running ALS ?
Your ALS will not work on idle, but only on higher revs, on the overrun, or by reving the engine.....
Old 19-03-2012, 10:44 AM
Themistoklis
With warm engine and is connected without the Idle air control valve, the engine is 900 rpm.
but if the link is going up at 1500 rpm while the engine is warm
i have modified the Idle air control valve.
how many revolutions of the engine works; (ALS)
Old 19-03-2012, 10:57 AM
Heitmann
Heitmann's Avatar
as already said, check TPS, and perhaps coolant sensor...
ALS, will work with higer revs, and when lifting the throttle changing gear or on overrun
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
Fezman1
02-10-2015 01:22 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: anti lag system
