Camber problem on 2wd sapphire
Old 07-10-2011, 05:54 PM
xgar rwds
xgar rwds's Avatar
Default Camber problem on 2wd sapphire
Hey folks, I've noticed a bit of negative camber on the driver side front wheel on my sierra. It's been like this since I bought the car over a year ago & I always thought it mite of been the hub was bent. While fitting new tcas I replaced the hub with a spare one I had &it didnt make any difference. Also tried 2 other different shocks & had no luck with that either. I bought a cheapy set of camber gauges & it reads 1.5 deg positive on passenger side &1 deg negative on driver side with the car jacked up. The cheap gauges go on the brake disc so had to take the wheels off. Shouldn't both side be the same or close to each other? Going to do some more measurements over the weekend. Cross member looks ok but could the strut tower be turned in a bit or bent? Thanks.
Old 07-10-2011, 06:29 PM
Turbosimpsons
Turbosimpsons's Avatar
has the car had a prang in it's previous life.
Old 07-10-2011, 06:31 PM
Pics fella.
Old 07-10-2011, 06:33 PM
Is it wearing tyres off on the edges.
Old 07-10-2011, 09:24 PM
xgar rwds
xgar rwds's Avatar
Doesn't look to have been damaged but could have been sideways in to kerb or over a few bad speed bumps in it's life. No not wearing tyre at all but it's annoying me cuz it's noticeable & I can feel it driving it. Thanks for replys lads il try to get pics up when I get her back on wheels.
Old 07-10-2011, 09:51 PM
botters
competant bodger
botters's Avatar
make sure its got a matched pair of lower suspension arms ive seen two different cheepo brands side by side and one was slightly longer
Old 07-10-2011, 10:40 PM
cossie.087
cossie.087's Avatar
i have the same on my 4b mine is nearly minus 3 and like yourself changed everything do some more checking when i get interest back.http://
Old 08-10-2011, 07:58 AM
xgar rwds
xgar rwds's Avatar
Yea that's very similar to the way mine sits. Bottom arms are a matching set but even so it was like that with the old arms as well. It's only now if got my finger out to try & find the problem. Its never my luck to sort things like this easy! Thanks for help & pics fellas.
Old 08-10-2011, 09:12 AM
J1mbo
B1mbo
J1mbo's Avatar
Depends what suspension your on but konis are common for bending at the bottom with a bit of a knock
Old 08-10-2011, 12:24 PM
xgar rwds
xgar rwds's Avatar
tried a few different shocks aswell j1mbo but still the same.
Old 08-10-2011, 02:03 PM
Turbosimpsons
i'd be inclined to have the chassis checked for straightness.
Old 08-10-2011, 09:13 PM
xgar rwds
xgar rwds's Avatar
Done a lot of messing about with this today, changed cross member & made no difference then we done a bit of measuring. Driver side strut tower is turned in a bit but no damage to chassis legs. Slight kink in inner wing but hardly noticeable. I'm taking her up to work to get put on the bench nxt week so hope to get her sorted. Thanks.
Old 09-10-2011, 03:05 PM
Turbosimpsons
sometimes if it's had uprated suspension on it could bend the strut top in. it would only take a small amount at the top wich would exagerate it at the bottom. if youv'e got a kink in the inner wing i'd say it's probably had a bump in the past. hope you get it sorted.
Old 09-10-2011, 06:32 PM
xgar rwds
xgar rwds's Avatar
Thanks man il let u know how I get on.
Old 09-10-2011, 08:40 PM
Bloomers
Cornish Fasty
Bloomers's Avatar
check the strut top rubbers. one of my new ish polybush ones split under the cap, and put it slightly off
Old 09-10-2011, 08:56 PM
AndyPen
AndyPen's Avatar
Has it got a brace fitted as these help a lot?
Old 10-10-2011, 08:53 AM
xgar rwds
xgar rwds's Avatar
yea checked it bloomers, even with the top rubber off & the stut loose i still cant make it get anywhere near the right camber. no strut brace fitted andy but will be if i get her fixed. not worried to much about the whole thing as its far from a concourse cossie but odd angled wheels really annoy me so il have to fix her one way or the other! cheers.
Old 10-10-2011, 04:36 PM
Paul_RS
Paul_RS's Avatar
Brace her up lad
Old 11-10-2011, 09:10 AM
xgar rwds
xgar rwds's Avatar
yep got 1 sorted lastnite paul!
jason_nike
18-08-2019 10:53 AM
FlashRS
13
31-08-2015 06:02 PM
Marc sierra
12
30-08-2015 10:38 AM
markk
18
17-08-2015 05:19 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: Camber problem on 2wd sapphire
