cosworth arms
Old 18-05-2011, 11:50 AM
Thanasis
Thanasis's Avatar
Default cosworth arms
Hello all,i would like to ask about the front track arm from 4x4 sierra cosworth, so are they the same with the 2wd ?thanks a lot
Old 18-05-2011, 12:25 PM
cossie604
cossie604's Avatar
Not sure regards 4x4 to 2wd saff mate, but I do know that 2wd saff arms are different to 3dr cossie arm's....so I think you'll also need to be sure what hub carriers your using at present mate.
Old 18-05-2011, 12:35 PM
Thanasis
Thanasis's Avatar
Hi mate,mine is not from 3dr but from 2wd sapp '89-'90 model thank you
joffy
SLOW LEARNER
joffy's Avatar
depending on the hub type you have, one is pinch bolt type and the other is a castlated (sp?) nut, i believe the 3dr is the pinch bolt but dont quote me on that
Old 18-05-2011, 12:38 PM
Thanasis
Thanasis's Avatar
i have from 2wd sapp hubs mate
Old 18-05-2011, 05:59 PM
cossie604
cossie604's Avatar
Cool, just as long as you know fella
Nah I wont quote you, only because your wrong though lol Other way round mate, saff uses the pinch bolt, 3dr is has the castellated nut
Old 18-05-2011, 06:54 PM
Thanasis
Thanasis's Avatar
so the 2wd from sapp with pinch bolt and 4x4 with pinch bolt too are the same? thanks
Old 18-05-2011, 07:02 PM
cossie604
cossie604's Avatar
As I said mate, I dont know regards the 4x4. Just wanted to make sure you knew there was two different 2wd lower arms before you tried matching 4x4 to them.
Old 18-05-2011, 07:14 PM
99.9% sure the 2wd and 4wd are different on the sapphys even though using same pinch bolt fitting, I'm sure it is a dimensional difference, or may have come about as ford listed 2 different sapphy arms for 2wd and 4wd, possibly due to the 4wd having a much stronger joint as drive also going through hubs ?
Old 19-05-2011, 01:02 PM
Thanasis
Thanasis's Avatar
ok,thanks all
Old 19-05-2011, 02:17 PM
PAUL S
PAUL S's Avatar
2wd saff cosworth arms are the same as both 4x4 saff and escos ones.
Old 19-05-2011, 05:16 PM
Thanasis
Thanasis's Avatar
thanks a lot mate
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
Quick Reply: cosworth arms
