Oil Filter
Old 09-04-2011 | 05:35 PM
cossiejsy's Avatar
cossiejsy
Default Oil Filter
I have just tried to remove my oil filter and its so tight that when I use the wrench its just crushing the filter and if anyone got any ideas what to do next to remove it would be a great help
Old 09-04-2011 | 07:00 PM
MannheimAlex's Avatar
MannheimAlex
A big screwdriver and hammer it through the filter and us it as a lever.
Old 09-04-2011 | 07:58 PM
Before doing the above, put on a large jubilee clip as close to the block side as you can, tighten this then knock the adjuster part with a hammer, if this fails do above.
Old 10-04-2011 | 07:38 PM
cossiejsy's Avatar
cossiejsy
Thank you very much for the replys and managed to get it off today with a oil filter chain wrench
Old 10-04-2011 | 07:44 PM
Just make sure you don't use a filter wrench to replace it, they don't need it.
Another trick is to put some really rough emery paper on the filter, as this grips nice.
Although done often I don't like the screwdriver way, any loose material. shards of metal are right in your oil system when done that way.
tankybaby66
06-02-2016 03:24 PM
01-11-2015 07:53 PM
Brickhouse
14
03-10-2015 08:28 PM
Johnny Knoxville
30-09-2015 08:21 AM
