sapphire 4x4 green top lambda test strange
When I connect led tester to my L8 ecu and unplug Lambda sonde dont get any errors, but when I try to do Co adjust get 1 blink in 2 sec what means that is out of range. Same thing when i connect Lambda sonde...
When engine is started i get error 3+1 - Lambda sonde but in manual say that can be possibly "out of range" of adjustment. I try to adjust co screw but all the same...
Sone ideas?
Sone ideas?
Last Time, Get Off PF FFS
Unless tou know what your doIng it's best left to a cossie pro when it comes to adjusting co levels. People been known to blow their cossie engine by messing around with them for MOT's
to reset CO screw adjustment and set it to base settings need - 5 turns clockwise and 1.5-2.5 turns anti clockwise.
then check CO by CO meter - it should be about 1% at idle(950rpm)
jason_nike
18-08-2019 10:53 AM
