2wd axle beam
2wd axle beam
I was wondering if somebody could shed some light on a mixture of answers i keep getting!
Will an L reg granada 2.0 axle beam fit a Cozzy 2wd with 7 1/2 inch Diff?
I only ask as i am breaking one and also need a beam for my 2wd Cosworth.
Are the wishbones the same?
Many thanks for your help
Thanks for your replies.As i am breaking the car i will remove it anyway and check it out.
I will post back when it is off,to answer the question conclusively.
Cheers guys from your answers it is worth taking it off.
Resident Wrestling Legend
The Granada beams and sierra beams for the dohc engines all used the 7.5 inch diff with the 3.92:1 ratio so should all fit without an issue, but ford are notorious for swapping bits over at whim so this my not be the case for evry single car, but it's been the case for evey single car I've stripped/worked on and that's plenty
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
