cosworth running badly, with video HELP?
saphire cosworth
running stg 3
greys
t34
3 bar
l6
etc...
car started with a slight missfire on low revs but cleard & has slowly got worse
i cleaned up all plugs other week & it ran on 4 & went like the clappers! ran sweet as a nut
i have orderd new plugs but they havnt arrived yet
i have:
removed all plugs again& cleaned them up & sheck they are all sparking (all good)
so thats plugs/leads eliminated
checked timeing (all good)
all injectors spraying fuel
tested map sensor on a mates car (good)
tried another CPS & it still ran the same
i have taken a video of the car running 2day & u can see how rich the car is running as it fills my unit with smoke in seconds!
if i unplug the TPS the missfire clears when revved (2nd half of video) but still runs lumpy on idle (like its on 3)
i have tested the TPS & have:
3.5 volts with no throttle (closed)
0.4 volts full throttle (open)
looking at these results it looks like its not right on idle & is over fueling?????
i have checked the flap is closed & it is
any other idears?????
cant be anything major as the engine is sweet & ran fine the other day!
running stg 3
greys
t34
3 bar
l6
etc...
i have:
well i have tried another 2nd hand set i had kicking about & it was exactly the same??
i did order some new ones but had to wait for them to turn up as was outa stock, should be here 2morra so will try them.
thing is im offshore for 2 months sat so wont get to touch it till end march after 2morra
While its running on idle try unplugging the injectors one at a time to see if it momentarily goes back on 4.
Let it idle and missfire, unplug number 1 injector for a few seconds.... listen to see if it stays on 3 cylinders or picks up on all 4 momentarily. If not then plug it back in and repeat with the next injector....
Ive had a couple of Sapphs do very similar and it turned out to be the injector wiring making a constant earth somewhere thus keeping it open all of the time.
Worth a try for 2 minutes messing about.
will test wires to them 2morra thou
my mates old saph needed a new engine loom yrs ago as had failed
just looking for as much feedback as possible so i can spend a gd day on it instead of a hr here & an hr there
defo isnt a mechanical fault as was running mint other day & u can see by all the smoke how rich its running
im thinking its fireing/running on all 4 but its overfueling that much its running rough???
2wd throttle closed you should see voltage greater than 4.5V between pins 11 and 17 on the ECU
2wd throttle open you should see voltage less than 0.5V between pins 11 and 17 on the ECU
Have you checked the condition of the phase sensor also?
SIERRA RS 4X4 COSWORTH
Was thinking myself , iscv sticking causing overfueling ......did happen on my saph .
Regular cleans with carb cleaner sorts the problem.
changed the blue sensor in head today, ran it up & ran loads better & thought it was sorted untill i realied the TPS was still unplugged, plugged it back in & its running like a nail again lol
no not yet as it looks a rite pain to get to the screws???
havnt played with the loom & correct wire is on the ISCV
i done it via pin 1 & 17 (1 is earth)
no not checked phase sensor yet but is on the to do list now
i will also try cleaning ISCV
no not touched the ecu as the car ran fine before
i will try replace all sensors when i get back, if no joy i will just have to take it sumwhere & get it sorted
Anyting forsale let me no
I done the same thing, i was kicking myself of hours there so nearly the same colour till you look in the day light.....
Try brand new plugs first. As the missfire has gotten progressively worse thats where i'd start. Then leads, then dizzy car and rotor arm. Most of those are cheap to change, so best doing them before you get stuck into expensive/hard things.
My brother had something like this last year. In high revs he had misfire's. Had changed the plugs twice with brand new ones, but only the 2nd set solved the problem.
K***LMT
i ment this
http://cgi.ebay.co.uk/Group-Coil-Gen...item2559a100ef
just wonderd if you tried another coil, might be wrong plug gaps blowing out the spark?
weak spark maybe ?
weak spark maybe ?
yer i did try a std coil on it the other week as had a very simular prob on my escort cossie & turned out to be coil. but didnt make any differnce on this
Check out my last page(s) of my car ... link below.
I was chasing a missfire for a while (got progressively worse) ... over-rich and terrible at idle.
Fixed it with changing the phase sensor (was visibly bad) AND the fuel regulator (still think this had a lot to do with it) as fuel had perished the sense line from the reg to the manifold due to an internal leak.
Hope this helps ... good luck.
got home 2 days ago & had a play with this 2day:
turned out to be the fuel pressure regulator
turned it out 1/4 of a turn & its spot on now!
cheers 4 help anyway guys
