Bad brake judder
Bad brake judder
I brought a set of ap 330 discs and modified 2wd calipers from a friend of a friend of a friend sort of thing for my 2wd cossie. Iv had them sitting around for ages and finaly got round to fitting them just before Xmas but since fitting them I'm gettin very very bad brake judder through the steerin to the point it feels like the dash is gonna fall out lol.
Could it be the discs warped or could it be something different causing it?
Thanks
Thanks
Modified calipers? Someone has modified standard calipers to make them accept 330mm discs? Have you got a picture? Depending on the bracket you may find the caliper is flexing under load. I have had warped discs and got a gentle wobble rather than a dash shake.
Look at the discs to see if there's an unusual wear pattern. Fix something very close to the disc and spin the disc keeping an eye on the gap to see if they are warped in any way.
I reckon it's a caliper issue though.
Charlie
Charlie
Charlie
Charlie
Basicly my mate brought a cossie with them on (iv been in tge car many time and he had no problem with them) then he broke the car and sold them to his mate, then the same again he broke that car now iv ended up with them but I'm getting bad judder so I don't know if that person has warped tge discs or what,
The only think I have noticed with them is the only way I could fit the brake pipe was through the bleed nipple as the bracket would of been in the way, could that cause problems?
he broke
