external wastegate connection?
I'm no expert like, but if you want to plumb a bleed valve in, isn't it similar to an actuator set up.? Take the outlet from your inlet turbine..pipe into bleed valve the from bleed valve to wastegate so you can tinker with the pressure.
What controls the wastegate normally, and how is it adjusted..different spring rates.?
Mark RS
12-10-2015 06:01 AM
