T5 gearbox rear oil seal
Old 25-09-2010, 04:11 AM
cozzierich
cozzierich's Avatar
Default T5 gearbox rear oil seal
Hello,
Does anyone have a part number for the rear oil seal (e.g. SKF, TIMKIN, etc). I am trying to cross reference a part number here in the states.
Old 25-09-2010, 04:19 PM
cossie604
cossie604's Avatar
Cant you just use the dimension numbers off your old one, its a standard seal ie nothing one off.
Old 25-09-2010, 06:39 PM
cozzierich
cozzierich's Avatar
Fortunately I was able to find it on SKF website and found it at a local autoparts shop.
For future reference the SKF part number is 13963. The seal dimension shaft=35mm, Bore=55mm, OD=55.16mm
Old 26-09-2010, 11:08 AM
35 55 55.16 ?,
assume this is inner/outer/width as per normal number sequence are they really that wide ?
Old 26-09-2010, 04:13 PM
cozzierich
cozzierich's Avatar
Originally Posted by tabetha
35 55 55.16 ?,
I am not sure what the difference is between the bore dimension and OD. It must have somthing to do with it being an interference fit.
This is how it is quoted:
Shaft
35
Bore
55
OD
55.16
Width
Weight
0.021
I forgot to mention the width in the original post.
Old 26-09-2010, 06:33 PM
Yes as you say the "added" 0.16mm must be due to the interference fit, so the actual seal is a 35-55.16-8 handy to know saves me hunting if mine starts leaking, thanks for the info much appreciated.
YODI
30-08-2015 01:12 PM
Danielbetty
28-08-2015 08:01 PM
JoeyBoyden
20
22-08-2015 03:23 PM
st220kyle
16
14-08-2015 06:13 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: T5 gearbox rear oil seal
