Sierra Diesel
#41
Your talkin sh** now
will b doin the p100 over the winter mate just collectin most of the things al need at the moment, as ur awear the starter on a transit engine bolts in from the side flush against the block and bell housin, but if u fit the sierra gearbox then the bolts for the starter(2.8 v6) go in from the rear of the box through the bellhousin and into the starter that sits down the rite hand side of the engine lookin at it from the front of the car/van
#42
A friend of mine has a Toyota Litace 20 turbo diesel fitted to his sierra. He says it`s from a Carina though. With its original ford type 9 gearbox mated via a custom made adapter plate and custom engine mountings
#44
Very interesting combo,Like to see a pic's of it if yea coud
#45
Turbocharging Technician
Is that a common rail engine or rotary pumped one with a throttle cable?
#46
the gearbox and mechanicals is the easy bit, how will you run your PD/common rail engine? which loom and management will you use? how will you get past the imobliser?
#47
M3 Motor Company in Bathgate (BMW specialist) built my transit recovery truck and fitted a BMW 325tds, remapped with a bar of boost and a front mount, 170 - 180bhp. It is mounted to the transit gearbox. Not really relevant but anything can be done if you're good at fabricating, wiring etc or you have enough money to pay someone else ha.
#51
#53
how about a 1.8 focus tddi engine with twincam sierra box and few old sierra td bits bolt it all together should be handy enought get up your end or country and lot less wiring than tdci engines
#54
he would need the loom, ecu, keys, dash and gearbox speed sensor (as a minimum) to get it running
#55
#56
deisel deviant
used the bmw gearbox and made a prop up https://passionford.com/forum/restor...ll-it-fit.html
theres the build thread feel free to have a look
wowk
30-03-2021 07:49 PM
chowfornow
14
05-01-2019 09:01 PM
SMILER258
28-09-2015 09:04 AM
