flywheel puller
You could make one easy enough, but you may not need one, it may not be that tight, if it is though after getting off lap it with some fine grinding paste between it and the crank nose, so it's not quite as tight, then will come off with very easy finger pressure.
sorry yes the crank pully,
cheers tabetha, i'll remember to do that. like everything on my car, i'm counting on it not being straight forward
