f***ing b****d cossy im going to break it soon....
#41
Don't mention ze Vor
That's what you get for learning english on Passionford. Mind you, the first day in the "real" england was quite hard, though. Thank god I found out that "can i bum you" is not an appropriate greeting before I approached that female border agency officer at Stansted Airport...
#43
sideways all the way!
Sorry jaiscossie for taking your post the wrong way
I been on the RSOC website for 20 years and had my 3 door since 1987 but only just joined Passion Ford , i am surprised by the number of people wanting to break a cossie for parts, there not difficult to work on and whatever problem you have there is always one of us who have had the same trouble and know how to fix it .
1. Go out and bum some random minger to relieve the anger!
2. Find out if it's ignition cutting out or whether it just doesn't get enough fuel. If it's fuel starvation it will get worse the more you depress the go-pedal! Could be fuel filter or a pump related problem then. Ignition problems mostly occure at low rpms and high boost.
I'm not sure about the Cossie WeberMarelli stuff but on normal Fords of that age (EECIV) the MAP sensors occasionally packed up with similar symptoms. If you unplugged it, the ECU would run the engine from the other sensors (TPS, CPS). Not sure if this works on a Cossie and how prone to fail the MAP sensors are. The symptoms would be similar though
PS: I've only spent about 3 weeks in the UK in all my life but I've already seen more Scoobies there than I have in the other 25 years in Germany...
arr reet nice one dude
i wound up with half the kebab down the front of me and a pissed off blond laughing at me
still didnt let me rub my face in her tits the bitch
yeah ill try that aswell,been meaning to put one on it for ages.
#47
"Ill check the stock"
Az you have been told so many times to get a map sensor as yours is not working at all!
and remember that night u took me n ashton out in it it cut out and we riggled a few wires and she fired up thats why i think its a dodgy wire?
#50
arr that simple i wish
#52
i had similar,took ages to work out that it only started doing it when id fitted babyboard and chip in ecu,turned out to be a dodgy connection on one of the wee plugs in ecu,
know how you feel tho,you get one bit done and theres something else wrong,getting sick off it myself,can see mine getting sold or broken very soon!
#53
cheers for suggestions lads
matt2474 im not spending on it at all,fucking sick of it,ive got a fuel filter and everything else will get checked or see if i can try me brothers on it cos his runs right,if i find it ill sort it,if not it can sit and rot for all i care at the minute.
#60
With reading this kosman i'd be checking the connectors on these wires and cleaning the pins and applying a little bit of vasoline, also check for breaks in the wires can get a bit brittle the age they are.
#63
massive massive thanks to 'fathead'
this is my mate who has sorted my cossys running problem,ive got a map sensor coming and we been at it all day,we checked everything couldnt find the problem
so i threw the towel in and told him fuck it,ill park it up again,he drove it back and it conked 3times,he was convinced it was a spark problem,grabbed the coil lead and straightened it while i cranked it and it fired up! it died as soon as he bent the coil lead again,so matt lewis will be getting a call on tuesday im so happy its sorted,shit will be at fordfair
thanks for all the help and suggestions lads
#67
yeah dude and something i should of checked first,but it being a cossy i never thought itd be something simple
cossie4i - cheers for offer dude but my bay got a blue theme going on so going to get some blue motorsport leads off matt
#68
Why would smashing 2 diffs make me feel better, but it would be very interesting how you done it unless your running 600 bhp.
And why you want to scrap a cosworth becuse it has a small problem like you have, take it to someone who knows what their doing and they would fix it in half a hour.
How did you smash 2 diffs if it only runs for 2 minutes.
#72
FUCK ME I DONT BELIEVE THIS CAR
i did the map sensor,the coil lead and fuel filter,ran like a dream saturday,i kicked its head in for 20mins with no myther,then sunday it was idling outside me house and it stalled,turned over and over then wouldnt fire,left it a few mins and it started again!
anyone got anymore ideas?
#77
My saph started to cut out a few mths back your were driving along then out of the blue she just cut out and the dash board lights would go of as well when i turned her over there was no lights comin on and she just turned over then eventually she fired up but done it again within 5 mins now when i go to start her there is no lights comin on on the dash and she just turns over shes fitted with a clifford alarm but its ok it would remind you of the fuel pump switched off the way she turns over but i have turned it on-off but to no avail any ideas lads ???????
#78
Received 1,044 Likes
bloody hell mate i thought it was all sorted. Are the 3 big electric connections on the bulk head ok. Make sure the pins arnt corroded. Also check crank position sensor connector. Mine was full of water when i was having faults. Is ur fuel pump priming too.
#79
coolant temp sensor seems ok,any way of testing it? checked crank sensor and plugs glennyboy,there all mint,it did it this time while it was sat still,last time it only did it when it was on the move,cant undastand it,and yeah the fuel pump still primes.
