Rough power for my spec ?
23-04-2010, 08:51 PM
200 block,7.8:1 compression,l&b bottom end,nick waples ported head,t34.63,33psi boost,standard cams,siemens 55's,500 cooler
23-04-2010, 08:58 PM
about 225bhp if your lucky kev
23-04-2010, 09:01 PM
Quote:
Originally Posted by
james kiely
Damn i thought 230 lol.
23-04-2010, 09:03 PM
saff is working!!!...atm
what "can" ur turbo produce............end of
23-04-2010, 09:04 PM
I'd guess at 380 bhp, 380lb torque.
23-04-2010, 09:06 PM
ok kev you might get a bit more
,i reckon 400bhp/380lbs
when are you getting it rolling roaded kev
23-04-2010, 09:07 PM
KSA-Cossie
i'd want 390 at least from that spec; is it being live mapped? if so a tad over 400 should be expected
23-04-2010, 09:14 PM
james kiely
Set up @ MSD 1st,so couple of months yet maybe.
LHD220Turbo
Got an off the shelf chip but going to MSD for a tweak.
23-04-2010, 09:15 PM
Will be changing to r/b t38 if i dont get 400 bhp lol.
23-04-2010, 09:20 PM
we can get you damm close to 400 but we will have to push the turbo hard
if you swap to a t38, i would go 83s and air injector aswell
going by brammers 3 dr, the t38 out flows the 55s and we had to cap his power
23-04-2010, 09:21 PM
Back in black!
going by what mine does and the extras yours has I am going for 405bhp and 400lbs
23-04-2010, 09:23 PM
James @ M Developments.
Would that need live mapped james ? Will be coming down for a tweak hopefully in may/june m8.
Matt Baxter
Sounds good to me matt.
23-04-2010, 09:27 PM
we could do it off the shelf, but to get the most out of her a live map would be better suited not sure we have done many roller 38s yet
23-04-2010, 09:29 PM
Cool,will get a chin wag with you when i come down m8.
23-04-2010, 09:31 PM
23-04-2010, 09:32 PM
ps, book fast, may is nearly booked up already
Didn't stu tell you i bring down a mahoosive special box lol.
23-04-2010, 09:33 PM
kev why not go for a t38 ,as you know you will want more power in a couple of months when you get used to 400 bhp on a .63
23-04-2010, 09:35 PM
24-04-2010, 07:51 AM
james kiely
It's a possibility.
Oooerr missus.
24-04-2010, 12:18 PM
Zee Germans are coming
get some cams in there to go with the rest of the spec
a 16 and 14 will be nice
24-04-2010, 12:24 PM
Tbh was thinking more of a t38,how much more will i get changing cams,i have valve cut out pistons btw
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
phil51
Ford Focus Diesel
02-10-2015 01:00 PM
dojj
29-09-2015 10:32 PM
deathrider666
28-09-2015 06:12 PM
