Burst CV Joint boot
Burst CV Joint boot
I've a problem with my front inner cv joint boot at the diff side.
2 months back i discovered it was busrt badly, so ordered a new one from Ford and replaced it.
Drove the car for some day and checked it and everything was ok, now i changed the wheels for winter i saw there's a lot of grease on the underside so checked it again and now it's burst all the way round
What can cause this as everything seems normal under the car and i really have no clue as in 6,5 years it never happened
Here's a picture, not the best
Thanks in advance
Thanks in advance
Have you checked your engine mounts mate this happened to my bros kept killing boots and it was the mounts they looked ok but when we lifted the engine to check they were split in half.
(we only found out after he tried to do a doughnut in the wet and his driveshaft exploded ha ha)
Hi Wim, how you're doing mate?
I always have green at the light so
Car is barely lowered at the front so don't think that's the problem
Ronnie mentioned on the Sierra forum that it could come by a knackered cv joint so checking that also
Maybe it's just bad luck
Hey,
have also seen those when there is too much grease in there. But I think them boots came with a tube of grease that is the right amount to fill in... well, so came with mine
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
