electrical display fault. 3DR
the light display to show if doors are open, lights are working etc does not seems to be working, bits of it work but most if doesnt also the engine managment light, fuel etc - all lights along the top part also do not work. any ideas wat the issue is - none of the connections are loose, possible bad earth ????
cheers
ben
cheers
ben
Normally it is caused by earthing problems, normally remaking the earth connection sorts it, there are two parts to it the main ECU is behind the drivers side kick panel, and the bulb outage monitor is behind the passenger side kick panel.
This is for a 2WD saph, I presume the 3DR will be the same as well.
Martin
Martin
looking for a 3dr dash warning light module that controls the ecu, fuel, water light etc, it also controls the birdseye view warning indication screen - if doors are open, lights are open etc.
saph and 3dr ones are different- needing 3 dr. saph ones have a pink sticker on them.
3DR PART NUMBER - 86BB-10K910-AA
cheers
ben
cheers
ben
