intercooler advise
intercooler advise
right im running stage 3, greens,3 bar chip rs500 cooler t34.63 but i get lots of turbo lag, i collected some parts from i guy today who told me if i run a 4x4standard cooler i will lose the lag? whats peoples views on this? just wanting so views before i start looking for a 4x4 cooler
i get nothing before about 3500rpm then it boosts realy hard its fun but i find you have to change down more to keep the revs in, i done a rwyb at shakespere last week end i found it realy hard to launch, if i launched below 3500 it bogged down anything over 3500 and i got wheel spin into third,
at stage 3 (330 bhp or there abouts) you will benefit more from a .48 mate rather than the .63. The .63 is good when going above 350 where it is needed, but lower down it has no real benefit and will cause more lag. Always found my t34.48 very fast on spool up.
it was chiped and set up at tourque of the devil its running 306bhp at 300lbs ft im thinking of going to siemans blacks and a gt30? would this make thinks better?
a t34.63 turbo will piss 380hp all day long (although in your spec you are not going to be getting the most out of the turbo due to the injectors. the injectors will max out before the turbo)
are you running standard compression with standard cams? if so then i think you're car is poorly set up which is why its not driving very nice.
i had t34.55 with siemens blacks and 2 bar/ 30 psi of boost, MSD chip. It drove perfect off boost and came in with a bang, no changing down required.
personally i would ditch the Greens; get a set of siemens 55lbs injectors & MSD chip. Increase the boost pressure to around 32psi (peak) it makes for an awesome road car and feel completely different. You can get as much as 36psi spike but the turbo might not last long.
gt30 isnt needed; you will be wasting your money - yours just isnt set up right in my opinion
im not that happy with how its been set up to be honest, think i will give it a service, and cam belt change over the winter then get it set up again
