205, standard bottom end, max power?
stock bottom end with mahles and stock rods, 1.75mm wrc head gasket, what boost could i run on t34/t4 turbo before its at its peak?Oh and of course supporting mods and a tune by stu at msd.
cheeRS
cheeRS
Will get lots off different answers on this mate, im on a low milage 205 in my saph, t34.48 and 28psi, could be a timebomb but i have a spare block to go in if it lets go
ive herd of people running 450
well i havent bought one yet, Il be after over 350bhp anyway, what turbo is good for 400+? t34's are only good for 380 arnt they?
il have b14 inlet and std bd8 exhaust cam iirc?
i would personally go for a T34.63 you should see a gen 370-380 bhp fit either black Siemens (55 ones will be fine!)or bosh light blues(400's) or greys (403's)although i think if u have a 2wd inlet plenum she will struggle to cope with this flow rate!
i presume you have the other bits in peices ready?like grp a fuel pump and rewire (for peice of mind!)500 type intercooler etc
il have a 044 pump mate and rewire, 403 injectors, Wrc headgasket,sweedish plenum, rs500 cooler, 2wd manifold, -34 actuator, 3" exhaust, 3 bar map etc etc and the chip sorted my stu at msd...
What about cams? what should i get?
I like the sound of a solid 370-380bhp, do you think my internals will take this? and what clutch do you recommend? cheeRS!!
track.focus'd
12-08-2015 05:53 PM
