sierra 24v build
check out ford power for your 24v questions: loads of conversions done there - link below.
http://maddoldbugger.powweb.com/forum/index.php?act=idx
Yes, 2wd MT75 will fit 2.9 RWD MT75, same for T9.
BOA PAS pump is identical to DOHC PAS pump, DOHC pump pulley is slightly bigger, will fit though.
You'll need:
loom & ECU
box (V6 T9 or MT75, T9 is dodgy on a 24v, but has better ratios.)
fanswitch & adapter
some fiddling with fuellines. I used rubber fuellines to connect fuelrail to original DOHC hard fuelines (underneath car)
You'll need:
loom & ECU
fanswitch & adapter
nico12
31-12-2015 04:42 PM
Adam Graham
06-09-2015 06:04 AM
