morette inner lamp air duct
thinking of removing the inner lamps on the morettes and having some sort of air duct instead!
has anyone done this and what is best way of modifing it so it looks good instead of just blanking off with lets say mesh or something like that.
Length of flexi plastic or alloy ducting to take a cold air feed straight into the standard airbox should see a performance increase if you are using an in-engine bay filter at the moment. Just go hunting for some suitable ducting. Dunno how you would fit it to the back of the Morette. Mine's all done with gaffer tape but that's not really a good long term solution.
Charlie
Charlie
As above lots of companies sell the universal type round ducts, if underbonnet is nicely vented don't expect to feel any increase.
Make sure your outer lights are dip and main beam(needed for mot) as some could be single filament depending on which light unit's used.
Steve Escos
01-10-2015 06:57 AM
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
