Sapphire bumper sagging
My front bumper has started to sag slightly
Its the main part where the number plate fixes onto. Does heating them, jacking it up to straighten then leaving to cool work?
Any other suggestions?
Take it off. Only fixed at sides NOT at the front. The front bracket arrangements adjust the height only and it's these that fail causing the sagging.
Repair height adjustment brackets (it's obvious when you remove the bumper) although the repair can be a bit tricky.
Whilst you got it off repair side fixing brackets also as this fixing also fails.
Anyting forsale let me no
Yeah, its the bit just above my number plate. You can sort of see it in my sig.
I checked the main metal bumper mounts last year when i had the bumper painted and they are fine...
I realise that but in order to solve the issue you have to remove the bumper and it's fixed at the sides only. The centre 'brackets' fail and thus the bumper sags but it is not fixed at the centre. HTH
Little update
Got it sorted! Turns out all i had to do was adjust the centre mounts and my problem was solved
I also noticed the plastic of the bumper was coming away from the backing foam, right at the top, so on my painters suggestion i shimmed it out with some plastic. Think it worked quite well! Still have to fine tune it, but i'm happy its sorted
Before - you can see the gap above the number plate
After
After
Little update
After
After
hello mate where are these adjusters! what a difference i need to do mine, did you take any pics whilest doing it? cheers dave
They are just behind the bumper mate. They are Torx 40 screws on the bit that slides into the chassis legs!
I'm actually going to adjust mine down slightly, probably do it tomorrow night, so i'll get a few pics for you then
CheeRS mate that would be handy to see. car looks really tidy had much body work done?
It's only got 51K from new, but i've had the front painted within the last year.
Wanna buy it?
I just took my bumper off, if like me you still have the engine undertray on - its impossible to adjust without first removing that.
Wanna buy it?
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
