4x4 front diff
Resident Wrestling Legend
where the diff goes into the sump, there is a big o-ring that slots around the diff to stop this from happening
it's going to be engine oil that's leaking
unfortunatly, the diff doesn't come out past the crossmember as there isn't enough space for it, so crossmember out, or at least dropped, is the order of teh day
i'm sure someoens said that theyv'e done it without dropping it, but whenever i've tried to remove them, they've never had enough clearance
on the plus side, the o-ring is about 50p
but when mine went, it took 6 hours of labour to get it fixed
thanks mate it is as i thought have bagged a secondhand diff and sump so gona have sump bigwinged and gated and put strenghener plate in the diff so ill do it all in one hit i think had a look today and looks like diff is leaking too
Passion for Fords!
if its the o ring around the diff thats leaking , it wont be engine oil...
the diff can be removed completly and you dont loose any engine oil as the sump is a sealed unit,
the diff only seals against the sump to prevent the diff oil escaping
and the front diff comes out in about 20mins... no need to drop the crossmember.
if you undo the os rack mount and budge the rack forward it clears easily. and leave the top bolt in the diff, as it doesnt come out of its hole in place..just slacken it right off untill its out of its thread, and make sure when you replace the diff the bolt is back in its hole! and remember you need to strip the ns down and remove the shaft that runs through the sump in a sealed tube.
