3dr engine mounts different???????
just took a break from stripping my block and wandered over to the car to contemplate cleaning the gunk & noticed both engine rubbers are are different and feel to have different resustances is this right?
![](http://i278.photobucket.com/albums/kk108/sportvanman/DSC00143.jpg)
![](http://i278.photobucket.com/albums/kk108/sportvanman/DSC00144.jpg)
can anyone shed some light please ?
![](https://passionford.com/forum/images/smilies/roi.gif)
Think the bottom one is a Saph item. It matches the one I have just taken off my 2WD.
Picture at the top of my blog: http://racecarprep.blogspot.com/
Charlie
Charlie
New ones: http://cgi.ebay.co.uk/2wd-cosworth-e...mZ220361978040
char1ie-yes mate i do think one has been replaced,its just that the have different resistances,and will this have an detremental effect ?
ray2drax-yup one is a lot cleaner than the other,but so is that side if the engine bat (not alot like!)
also on what appears to be the 3dr mount there is a locating pin or summat that fits the alloy mountlng arm
There should be a metal cover on each side on a sapph, as each ones PIN goes through the engine mount arm each side.
I am sure 3 door are same as well, the bottom piccie isn't cossie I'd say, would also explain the different resistance too.
If I were you I would just buy a new pair (the Ebay link above) or go for an uprated pair in alloy. I have just bought a pair second hand and fitted them but I haven't driven it yet so can't report on the difference it makes.
Good luck with all the cleaning!
Charlie
thanks folks ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
are uprated ones that former will it shake the car much more as a mate of mine has themon his turbo civic & he had to change em,have heard that new standard rubbers will make a world of difference
oh and the cleaning no bother
,done most of the brackets and and ancilleries already
![tiff](https://passionford.com/forum/images/smilies/punchballs.gif)
yam yammer
I would definatley go for uprated ones mate as I had a standard one break on boost of my escos and cause the engine to hit the bonnet and dent it ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
I bought mine from Reyland and I'm pretty sure they are the same as the Collins ones. As for vibrations I haven't noticed any real difference to be honest
When they fitted my new engine in my 3 door last august i went to fords and bought 2 new mounts , they are the same as the 1st pic, and so were my olds ones that come off the car . £148 for the pair in fords
bigluke200
14
02-09-2015 10:35 PM
track.focus'd
12-08-2015 05:53 PM
lockie
31-07-2015 10:03 PM
