fuel rail question
11-02-2009, 05:38 AM
fuel rail question
is the 2wd rail the same as eeciv item? what is the diff?
11-02-2009, 04:12 PM
i think they are different; how they bolt up and the fuel reg is different
i'm not 100% certain but someone will comment who knows for sure
11-02-2009, 10:25 PM
LHD is correct. Different mounting points and the EECIV rail has a bosh reg fitted to it, where as the 2wd rail doesn't have any reg fitting on it. the reg is attached with a short bit of piping.
12-02-2009, 08:48 AM
so i need to use my 2wd item when i used the eeciv plenum?
12-02-2009, 06:24 PM
No, you need to use an EECIV one as the 2wd doesn't physically fit the inlet manifold.
18-02-2009, 04:10 AM
but i am using after market regulator... how can i rid of the org item?
Music & Car Audio Chat
03-09-2017 01:24 PM
155lee
27-10-2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
17-09-2015 12:37 PM
BRAMMER
15
14-09-2015 08:52 PM
andrewmctiernan
08-09-2015 03:05 PM
