205 block
08-02-2009, 08:02 PM
205 block
Hi guys my 4x4 seems to have a 205 block is the correct? its a 1990 build date
08-02-2009, 08:06 PM
Cossiemodo
Hi mate, there was a long thread about this in Gen Discussion a few days ago. As usual it descended into a bit of a bicker and there were some people saying that absolutely all 4x4 had 200 blocks, while a few people said some had 205 blocks.
My 4x4 had a 205 block when I bought it. But car had a lot of owners so I can't say if it had it in from new.
08-02-2009, 08:09 PM
Where do i find the engine number to check ?
08-02-2009, 08:15 PM
3 big numbers on the exhaust side of the block. either 200 or 205
Also check the engine number, think its on the dizzy side of the engine. You may well find the engine has been changed.
08-02-2009, 08:18 PM
I have just seen 205 when i took the inlet manifold off
08-02-2009, 08:22 PM
Quote:
Originally Posted by
cossie330
where do i find the engine number to check ?
stamped on the windshield wipers!!!!!!!!!!!!!!
T h e -b l o c k------------doh-
08-02-2009, 08:44 PM
i beleive that some early ones did indeed have 205 blocks
Checked the wipers but no luck, wherabouts on the block?
08-02-2009, 08:51 PM
This is where it is on the rs500 block - assume its the same but can anyone confirm?
15-02-2009, 12:11 PM
Just checked my engine number and it matches my vin and all my windows are etched with this number, so i am asuming that the 205 block is original from factory
15-02-2009, 12:38 PM
the 4x4 1990 i got also had a 205 block from new..
just in middle of rebuild with a nice 200...
15-02-2009, 12:49 PM
More boost Igor!
AndyPen
Mine's in the same place
Note: 1990 build codes start with L, so a 1990 one would be Lx12345
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
AJC
01-10-2015 06:47 PM
20/20 vision
29-09-2015 11:27 AM
20/20 vision
28-09-2015 03:03 PM
