Sapp water pump advice needed.
Hi all,I am going to change my water pump but the problem is whats the difference between a 2wd one and 4x4.Does the 4b one have more outlets or are they in a different place.My car is 2wd but it does have a 200 block this is why I ask.Many thanks for any advice given.
as above the thermostat housings and water pipes are differant also
if the thermostat housing has 1 pipe coming out of it then its a 2wd pump
if its got 2 pipes coming out of it then you've got a 4wd pump
as well just replacing with the same type as whats already on it so save swapping more stuff over
i see motorcraft water pumps on ebay for 65 - 69gbp. they state motorcraft, but if the pump from pinto engine fits cosworth engine, the items on ebay can be simple pinto pumps? how to recognize them? Thanks
Water pumps
My 3 door which has just undergone a major engine rebuild, had a granada/ cortina pump fitted. This could have been one of the many factors that contributed to the damage that the engine suffered. It now has the correct 3 door pump fitted. The fact that pumps from other fords fit, and look similar doesnt mean that they do the same job as the correct item.
Kind regards,
Martin.
jonfoc
16
11-09-2018 05:35 PM
155lee
06-09-2016 11:10 AM
Cossikev
13-09-2015 02:00 PM
