Ahmed stg3 330chip, L1
Does anybody know what the A/F ratio this chip is set to run on load? (up to 1,3bar boost)
Mine is running 13-13,2 all the way up to 1,3bar,..only did one drag i 4th gear. So no im not using it before i know more/got a decent setup,..Crappy chip?
New parts on the car; fuel pump, fuel filter, regulator, air filter, injectors(803), intercooler, spark plugs, all engine sensors,...Fuel pressure is 3,5 bar without vacuum,.
Thanks
Thanks
That is way too lean(on boost) for decent power, and more importantly engine protection, nearer 12/11.5 is better, though some put theirs to 10.5, which is just studpidly rich.
My idle afr is (warm) 15.8, but goes leaner than this on light cruise.
