Graphic Display Module and Warning Lights
Hello
Occasionally over a bump the two warning lights above the clock in the centre of the dash come on - i.e the one's for low petrol and low water level. At the same time the Graphic Information module shows all 4 doors open, brake light test, headlight test and ice warning ( basically it all lights up ).
I'm presuming it's a loose wire/multiplug etc somewhere in the connections/loom, maybe at the back of the display. Another bump and they all go off......
Anyone had this before - also what's the easiest way to get at the back of these 2 modules with as little dismantling of the dash as poss?
Do they pull out from the front.....or can you get at the back of them easily?
Any ideas? I hate electrical things/taking trim apart
Cheers Andy
in both kick plates in both footwells there are little ecus fo the light panel, ones a brake flaiure box and the other is a electrical ecu, think thats in the passenger, but sounds as tho the multiplug is not clipped in propely and is getting disturbed
Ah cheers for that info about the warning light ECU - never even knew there was one
Will check multiplug over the weekend ....if I can find it!!
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
Dr. Ickxs
15-09-2015 10:15 PM
The Enigma
12-09-2015 10:12 PM
