Fuse box
Fog light is number 17(20Amp) for front fogs.
Other fuses relays not in the main fusebox are abs relay/fuse(20a), pump(abs)30a fuel pump 15a, ecu 1a, located under glovebox area on metal bracket as well as air con(purple), some cooling fan, these are the main ones but there are more.
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
