fan fuse and relay
As the fans are on the engine side of the rad, they must suck.
As to the fuse the best advice is to forget the fusebox and do a seperate mini loom, as the fuseholder position always melts and causes blown headgaskets etc as the circuit is overloaded, this and a fuel pump rewire are the two most important things on a old cossie electrically speaking.
i found the problem,a blown 10 amp fuse in a 30 amp holde.r,as soon as i replaced it they worked,they had been working fine before on the 10 amp fuse.i read in another thread that it was another fuse so i had been looking in the wrong place.im having the fuel pump rewired when i get all the stage 3 bits put on,just waiting on a stud and nut kit coming and a head gasket set(just as a precaution)
