Headlights not working need advice/help
Old 29-04-2008, 10:29 AM
capri280
capri280's Avatar
Default Headlights not working need advice/help
Have a set of morettes fitted to my sapphire
Problem is the that the side lights ie the outer lamps are only working
The inner lamps ie main beams are not working but will work in the headlight flash function and thus its is not the bulbs
Any advice appreciated
Old 29-04-2008, 09:23 PM
capri280
capri280's Avatar
Default car
anyone
Old 29-04-2008, 09:44 PM
Tev
Tev's Avatar
Earth problem? or relay?
Old 30-04-2008, 03:56 AM
stevecossy
stevecossy's Avatar
As above or corroded connections, just done my mates rs2000 morettes and he had similar prob after car been stood in damp garage for 3 yrs. Some fool had also not mounted the relay so it sat upside down and had got water in it, It was rusty as hell inside.
Good luck.
Old 30-04-2008, 07:24 AM
capri280
capri280's Avatar
Default car
any ideas which relay or where is it and colour
thanks
Old 30-04-2008, 10:04 AM
stevecossy
stevecossy's Avatar
His was located near the lights and loose, was a green hella 25A relay.
Think the morette kit comes with all cables and plugs etc so yours should be somewhere in the light area, try tracing the cables back from the light units.
His was same side as battery.
Good luck.
Old 10-05-2008, 03:59 PM
capri280
capri280's Avatar
Default lights
anyone eles any ideas
just rechecked the two earths that are on each side of the car at the headlight cowels
also checked the switching units and the steering column
any idea
Old 13-05-2008, 03:25 PM
DAN400
DAN400's Avatar
did you get much interest in the car lad ?
YODI
30-08-2015 01:12 PM
Palethorpe01
15
18-08-2015 06:09 AM
COSWORLD
14-08-2015 07:40 AM
Escortdriver1
31-07-2015 02:36 PM
Quick Reply: Headlights not working need advice/help
