Saph Wiring
Old 26-02-2008, 06:54 PM
bigjim172000
Me Cossie Runs Atlast!!!!
bigjim172000's Avatar
Default Saph Wiring
On my G -reg saph there is an ECU in the left and right footwells behind each kick panel. On my new body shell the left hand one is mounted behind the glovebox on a bracket. and i cant work out how the right hand one mounts? Any ideas why the difference?
James
Old 26-02-2008, 10:47 PM
bigjim172000
Anyone?
Old 27-02-2008, 06:02 AM
The right hand one is NOT an engine ecu, the left hand one is NOT and engine ecu.
The 2wd were behind the dash where you describe, 4wd were under at the rear of the glovebox.
Old 27-02-2008, 10:01 PM
bigjim172000
Hmmm so what do i have to do to make the car run as a 2WD? I have my 2wd engine loom.
Old 28-02-2008, 08:50 AM
If you are fitting a 2wd loom into a non cossie base car a little wiring, if fittingh into a cossie car to start with it all just plugs in, at variuous points inside the car, then the loom obviously on the engine.
Old 28-02-2008, 05:21 PM
bigjim172000
it is a genuine cossie so no probs there. Just wanted to make sure i wasnt going after a lost cause
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
Quick Reply: Saph Wiring
