AP's on a 2wd
AP's on a 2wd
hi i have just put Ap's on the front of my 2wd saph.
ive had to put spacers on to keep them away from the wheel. has any 1 else done this and wot size did you go for?
also as i turn the disk catches the calliper has any 1 had this and any ideas how to sort this??
any advice will be a big help thanks again
I expect it's the wheels if your on 17'' Diamond cuts mate and not the brakes!
AP's are notorious for fitting perfectly and Diamond cuts are notorious for having crap clearance on brakes!
cant really say but i used a selection of very fine shims & spaced the caliper mount bkt out until it was perfectly central to the disc. have seen the caliper having to be radially spaced to prevent the disc rubbing on the inside of the caliper when driven hard & it heated up
the wheels are no longer catchin ive sorted that. the disk is catchin on the outside of the calliper.
its as though it needs to be further out i.e takein some off of the inside of the bracket
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
dojj
28
11-09-2015 10:00 PM
