fitting new phase sensor
Old 05-10-2007, 08:43 PM
shanemc
shanemc's Avatar
Default fitting new phase sensor
just wondering how to fit a new phase sensor,do they have to be lined up or adjusted or something?
thanks
Shane
Old 06-10-2007, 06:26 AM
If you are fitting it whilst the dizzy is in the car, then will be lined up already, so long as dizzy not turned, just leaves the gap to be set to 0.2mm - 0.3mm, make sure the phase sensor is sitting exactly parralell to the lobe on the dizzy shaft as some are it seems distorted slightly and need a GENTLE bend on the plate of sensor, as mine did but was new.
Once gapped job done.
If it is a new one it will be one RED wire one BLUE wire on the small leads from it to clip to inside of the terminal that goes through dizzy body, the red lead goes to the nearest terminal in the block, to the phase sensor.
Old 06-10-2007, 08:57 PM
shanemc
shanemc's Avatar
nice one cheers,fitted it today,it improved the misfiring under boost but didnt cure it,so i gapped the agpr12pp's down to .8mm,and cleaned the tdc sensor,now it pulls clean in every gear,and idles smoothly aswell instead of hunting up and down,happy out,for however long it lasts!
Old 07-10-2007, 06:39 AM
If you have not got one yet a group a or similar high powered coil will help big time.
Old 07-10-2007, 10:38 AM
shanemc
shanemc's Avatar
i have one i fitted it a few wks ago.next ignition mod will be a coilpack conversion,that'll wait till i get a bigger turbo for it thou.
Shane
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
manuel boeckx
13
03-10-2015 02:29 PM
Anutternutter
21-08-2015 06:07 PM
muz
16-08-2015 12:57 PM
Zoggon
10-08-2015 10:39 AM
Quick Reply: fitting new phase sensor
