wot oil to use on a fresh rebuilt engine(2wd)
Old 09-07-2007, 09:33 AM
andycosworth
andycosworth's Avatar
Default wot oil to use on a fresh rebuilt engine(2wd)
hi guys,wot oil do i use on a fresh rebuilt engine(2wd) ive have done 500 miles on mobil1 15/50,but i have been told that i shud b using a cheap mineral oil to help bed the new pistons n rings in as the fully synthetic protects it to much
any help will b most gr8ful , thanks andy
Old 09-07-2007, 10:12 AM
Daxcossie
Daxcossie's Avatar
I would be tempted to stick some mineral oil in there for the next 500 to 1000 miles and then switch to Silolene Pro S 10w-50.
Remember to do an oil filter change now and then again on the next oil change.
Make sure you keep the boost down low (under 7ps ish) and dont let it rev for any length of time. However on a run revs should be built up slowly and then let back down again.
Enjoy
Old 09-07-2007, 01:48 PM
Do NOT under any circumstances use a SYNTHETIC oil for running in.
Just use a regular mineral oil as said.
Old 10-07-2007, 09:17 AM
andycosworth
cheers thanks lads
Old 12-07-2007, 03:16 PM
rosscoe
rosscoe's Avatar
Default oil
i asked the oilman this very question the other day,he recommended at quality 10/40 mineral oil to run in,and then pro s 10/50 silkoline
top man
JoeyBoyden
20
22-08-2015 03:23 PM
JoeyBoyden
18-08-2015 10:52 PM
ekjim
17-08-2015 08:57 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: wot oil to use on a fresh rebuilt engine(2wd)
