Shim kit for rear
Testing the future
just to clarify a bit as he is foreign and may not understand the replies so far.
when you use lower springs on the rear, not only do you get more negative camber, but the wheels will also toe out more. as the trailing arm moves upwards, it also moves the front of the wheel outwards and the rear of the wheel inwards.
that change of toe is what makes the car handle worse with lower springs and increases the tyre wear on the inside edge.
the negative camber is not good for traction in a straight line as there is not as big a contact patch, so it is also worth correcting. that can be done by making the hole in the rear beam for the inner semi trailing arm bigger, and using big washers either side to set the camber. when you have what you want, you can then spot weld the washers in place. this is how group a sierra's used to do it
in my opinion, unless you have an adjustable beam, it is better to use standard height springs
Cake lover!
Nick i thought that when you lowered that it gave Toe out not in bud? Thats why the inside edges wear quickly.
The shims that i had of Stu are going on in a couple of weeks, the instructions state that they should be inserted at the back 2 bolts, this would then give you some toe in? or thats the way i understood it bud.
Thanks your replies.
I think items like this:
It is for camber not for toe, but a bit hard to fabricate it. Unfortunatelly my lowering spring got tired, and I have replace it, but here in Hungary there is no chance to get good spring for cosworth.
Testing the future
jonfoc
16
11-09-2018 05:35 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
grishenko45
09-09-2015 12:58 PM
